Automating Basement Lights for Alzheimer's Care
Hi everyone, I wanted to share my experience with setting up automated basement lights, especially since my father is in the early stages of Alzheimer’s. This setup has been a lifesaver for both of us. I hope this helps someone else facing similar challenges!
I started by replacing the old light switch with a smart switch. It was a bit intimidating at first, but the process was straightforward. I used a motion sensor to trigger the lights when he enters the room. The real magic came when I added automation to turn off the lights after 15 minutes of no motion. It’s simple yet effective!
Here’s how I did it:
  1. Smart Switch Installation: I chose a reliable smart switch that integrates well with my existing ecosystem. It took about 30 minutes to install, including wiring and testing.
  2. Motion Sensor Setup: Placing the motion sensor was crucial. I positioned it in a corner where it can detect movement throughout the room without being too intrusive.
  3. Automating the Lights: Using the rule editor, I created a flow that turns the lights on when motion is detected. I added a timer to turn them off after 15 minutes of inactivity. This ensures the lights don’t stay on unnecessarily, saving energy and reducing the risk of overstimulation.
  4. Testing and Adjustments: I tested the system thoroughly to make sure it works seamlessly. Adjusting the timer duration was key to finding the right balance between safety and comfort.
This setup has made a noticeable difference in my father’s daily routine. He feels more secure knowing the lights will come on when he enters the room, and I’m reassured that they won’t leave the lights on unintentionally.
I’d love to hear how others are using smart home technology to support loved ones with Alzheimer’s. Any tips or alternative solutions would be greatly appreciated!
Cheers,
