Hello everyone, I wanted to share my experience with automating the basement ventilation system using smart sensors and Home Assistant. I’ve been experimenting with this setup for a while now and thought it might be helpful for others who are looking to optimize their basement environment. The Challenge: Basement humidity can be a real issue, especially during the summer months. I noticed that manually opening and closing the basement windows was not only inconvenient but also ineffective in maintaining optimal humidity levels. I decided to automate this process using the data from my Homematic sensors and Home Assistant. The Solution: I set up a system that calculates the absolute humidity both inside and outside the basement. If the outside air is drier, the system automatically opens the basement windows. Conversely, if the outside air is more humid, the windows remain closed. This ensures that the basement stays dry without any manual intervention. Here’s a quick breakdown of how it works: - Outdoor Sensors: Measure temperature (Ta) and relative humidity (rFa). - Basement Sensors: Measure temperature (Tk) and relative humidity (rFk). - Calculations: Using the formulas for saturation vapor pressure and absolute humidity, the system determines whether to open or close the windows. Implementation Steps: 1. Hardware Setup: I used Homematic sensors for both indoor and outdoor measurements. 2. Software Integration: Configured Home Assistant to process the sensor data and trigger the window automation. 3. Automation Rules: Set up conditional statements to open or close the windows based on the humidity comparison. Challenges Faced: - Initial Calibration: Ensuring accurate sensor readings was crucial. I had to fine-tune the sensor placements to get reliable data. - Algorithm Fine-Tuning: The calculations needed to be precise to avoid unnecessary window movements. Results: Since implementing this system, I’ve noticed a significant improvement in basement humidity levels. The automated windows have prevented mold growth and have made the space more comfortable overall. Tips for Others: - Start Small: Begin by monitoring humidity levels manually before diving into automation. - Use Reliable Sensors: Invest in accurate sensors to ensure your system works as intended. - Regular Maintenance: Check the sensors and actuators periodically to prevent any issues from arising. I’d love to hear if anyone has tried something similar or has suggestions for improvement! Happy automating! ![]()
