Automating Bathroom Heating with Temperature Sensors
I’m excited to share my recent project where I integrated a temperature sensor with a smart switch to automate my bathroom heating. Using my HomeMatic IP system, I wanted to ensure the bathroom stays warm during colder months without manual intervention. Here’s how I set it up:
  1. Setup: I connected a HMIP-PSM switch with a temperature sensor. The goal was to turn on the heating when the temperature drops below 10°C and turn it off once it reaches 12°C.
  2. Configuration: Through the CCU2 interface, I programmed the sensor to monitor temperature changes and trigger the switch accordingly. It took some trial and error to get the settings just right, but the process was straightforward.
  3. Testing: Initially, I was worried about false triggers, but after adjusting the sensitivity settings, the system works like a charm. It’s been a great addition, especially during the winter months.
  4. Tips: If you’re considering a similar setup, I recommend testing the sensors in different areas to find the optimal placement. Also, ensure your CCU2 firmware is up to date for the best performance.
I’m curious to hear how others have automated their heating systems. Have you tried something similar? What challenges did you face, and how did you overcome them?
