Automating Heater Shutdown When Windows Open
As a homeowner who values both comfort and energy efficiency, I’ve always been on the lookout for ways to optimize my smart home setup. Recently, I stumbled upon an interesting automation idea that I wanted to share with the community, as it could be incredibly useful for many of us. Automating the shutdown of your heater when a window is open is not only practical but also helps in preventing unnecessary energy waste.
I came across this concept after noticing that some smart thermostats, like Tado, now charge extra for features that automatically turn off heating when a window is open. This seemed a bit unfair to me, as I believe this should be a standard feature. Inspired by this, I decided to create a custom automation using Home Assistant’s blueprint system.
The process was surprisingly straightforward. Here’s how it works:
  1. Monitor Window Sensors: The automation continuously monitors the state of a binary sensor attached to a window.
  2. Detect Open Windows: If the sensor detects that the window is open, it takes a snapshot of the current heater settings.
  3. Turn Off Heating: It then shuts off the heater to prevent heat loss.
  4. Restore Settings: When the window is closed again, the automation restores the heater to its previous state, ensuring that your comfort isn’t disrupted.
One thing I found particularly useful was adding delays to the automation. This prevents the heater from turning off immediately if the window is briefly opened, which can happen when someone is moving in and out of the room. The delays can be adjusted based on personal preferences, adding a layer of customization to the automation.
I also noticed that there were some known issues, especially with Tado devices, where the heater might revert to ‘heat’ mode even if it wasn’t the previous state. However, these issues were minor and didn’t significantly impact the overall functionality of the automation.
This project was a great learning experience for me, and I’m excited to share it with the community. If you’re looking to reduce energy waste and improve your home’s efficiency, I highly recommend giving this automation a try. Feel free to reach out if you have any questions or suggestions for improvement!
Let’s continue to innovate and make our homes smarter together!
