Automating My Bathroom Mirror with Shelly 1 – A Wonderful Experience!
I’ve recently embarked on a fun smart home project to automate my bathroom mirror, and I’m thrilled to share my experience! :star2:
For those who haven’t tried it yet, the Shelly 1 is an amazing little device that has completely transformed my morning routine. My bathroom mirror has built-in LED lighting and a heating function, both controlled by touch sensors. While this setup is convenient, it has one downside – the LED lights are quite bright and can be disruptive at night. Plus, there’s no physical on/off switch, which made it a bit tricky to manage the heating and lighting during different times of the day.
After some research, I decided to integrate a Shelly 1 into the circuit. The idea was to use it to control the power supply to the mirror, effectively allowing me to turn it on and off remotely or through automation. I was initially worried about whether the Shelly 1 could handle the load, but after consulting with an electrician and doing some testing, it turned out to be a perfect fit!
Here’s how I set it up:
  1. Power Control: I connected the Shelly 1 to the power supply of the mirror. This allows me to toggle the entire mirror’s power via the Shelly app or through my Home Assistant setup.
  2. Automation: I created a simple automation in Home Assistant that turns the mirror on when I wake up in the morning and dims the lights to a softer setting during nighttime. This way, I don’t disturb my partner if I need to use the bathroom late at night.
  3. Heating Function: The heating function is now automatically activated when the temperature drops below a certain threshold, ensuring the mirror stays fog-free during colder months.
The best part? The integration with Home Assistant has been seamless. I can control everything from my phone or even through voice commands using my smart speaker. It’s incredibly satisfying to walk into the bathroom in the morning and see the lights automatically adjust to the perfect brightness.
If you’re looking to add a touch of smart automation to your bathroom, I highly recommend exploring the Shelly 1 for similar projects. It’s affordable, easy to install, and incredibly versatile. Plus, the peace of mind knowing that I won’t accidentally flood the bathroom with bright lights at 3 AM is worth its weight in gold! :smile:
Has anyone else tried automating their bathroom mirror or similar fixtures? I’d love to hear about your experiences and any tips you might have!
