Automating My Ceiling Fan: A Learning Experience
Hey everyone! I’m diving into the world of home automation and couldn’t be more excited. I’ve been trying to set up my ceiling fan to turn off automatically based on a counter and presence detection. Here’s my journey so far:
I wanted the fan to turn off after 5 minutes if no one is detected and the counter is below 5, or after 20 minutes if the counter is over 5. I set up the automation, but it wasn’t working as expected. After some troubleshooting, I realized my logic might be off. I started by checking the counter values and ensuring the presence detection was accurate.
I decided to break down the problem. First, I tested the presence detection separately to make sure it was working. Then, I looked into the counter logic. I realized I needed to structure the conditions more clearly. I also considered whether the counter was updating correctly in real-time.
After some research and tweaking, I finally got it working! It was a great learning experience. I now understand the importance of testing each component individually before combining them. Here’s a tip for anyone tackling similar automations: start simple, test each part, and then build up complexity. It saves a lot of frustration!
I’m looking forward to sharing more as I continue my automation journey. If anyone has tips or tricks, I’m all ears! :blush:
