Hi everyone, I’ve been diving into the world of smart home automation, and I wanted to share my experience with setting up the Neato Botvac Connect vacuum cleaner. My goal was to create an automation that stops the vacuum when someone arrives home and sends it back to its charging station. While it took some time to figure out, the process was quite rewarding!
The Setup
I started by ensuring my Neato was properly integrated with my smart home ecosystem. Using MQTT, I set up the necessary topics for controlling the vacuum. The next step was configuring the automation rules. I used a combination of presence sensors and time-based triggers to determine when to activate the vacuum and when to send it back.
Challenges and Solutions
One initial hurdle was getting the vacuum to stop and return to its base. After some research, I realized the importance of using the correct MQTT commands to ensure smooth operation. I also discovered that timing was crucial—sending the return command too quickly could sometimes cause the vacuum to malfunction.
Final Automation Flow
Here’s a breakdown of how I set it up:
- Presence Detection: When a family member arrives home, detected by a smart door lock or motion sensor.
- Stop Vacuum: Immediately sends a stop command to the Neato via MQTT.
- Return to Base: After a short delay, sends the command to return to the charging station.
- Confirmation Notifications: Receives confirmation that the vacuum has successfully returned.
Lessons Learned
- MQTT Commands: Understanding the specific commands needed for the Neato was key.
- Timing: Allowing a brief delay before sending the return command ensured reliability.
- Testing: Incremental testing helped identify and fix issues early on.
Community Tips
If you’re looking to automate your Neato, here are some tips:
- Check Documentation: Review the Neato API documentation for MQTT command specifics.
- Use Reliable Sensors: Ensure your presence sensors are accurate to avoid false triggers.
- Log Everything: Keep logs of your automation runs to troubleshoot effectively.
Looking Ahead
This successful setup has inspired me to explore more complex automations, like scheduling the vacuum to run during off-peak hours or integrating it with my smart lighting system. The possibilities are endless!
I’d love to hear how others have automated their Neato vacuums or any tips you might have. Let’s continue to share and learn together!
Happy automating! ![]()
