Automating Outdoor Lighting with Sunset Triggers
I’ve been really enjoying setting up my outdoor lighting system to automatically turn on as it gets dark. Using the Zonnetijden app has been a game-changer for me because it takes the guesswork out of timing. I initially set it to activate at 5 PM, but of course, the days get shorter and longer throughout the year. That’s where the sunset trigger comes in handy!
I found that setting the lights to turn on 30 minutes before sunset works perfectly. It gives just enough time for the area to brighten up before it gets too dark. The best part is how seamless it is—I don’t have to adjust the time manually anymore!
I also experimented with different light intensities for various times of the evening. For example, having softer lighting in the early evening and then switching to brighter lights later on. It creates a nice transition and uses energy more efficiently.
One tip I’d share is to test the timing a few days in a row to see how it works with your local sunset patterns. Sometimes 30 minutes might be a bit too early or too late depending on your location. Adjusting the offset by a few minutes can make all the difference!
Overall, automating my outdoor lights has made evenings much more enjoyable without any hassle. It’s a small feature that makes a big impact!
