Automating Shelly Plugs with Shelly 1PM Mini Gen 3
Hey everyone, I’ve been diving into the world of smart home automation lately, and I wanted to share my experience with setting up a Shelly Plug using a Shelly 1PM Mini Gen 3. It’s been a fantastic journey, and I thought I’d walk through how I got everything up and running smoothly!
The Goal
My objective was to automate two Shelly Plugs in my living room. I wanted them to turn on automatically when a specific switch is toggled. The switch is connected to a Shelly 1PM Mini Gen 3, which acts as the controller for the entire setup. While I’m still new to this, I’ve managed to get everything working perfectly, and I thought I’d share my setup in case anyone else is looking to do something similar.
The Setup
Here’s how I configured everything:
  1. Shelly 1PM Mini Gen 3: This device is the brains of the operation. It’s connected to my home network and acts as the intermediary between the switch and the Shelly Plugs.
  2. Shelly Plugs: These are the devices I wanted to control. They’re connected to my lamps, and I wanted them to turn on and off automatically based on the switch’s state.
  3. Switch: This is the physical switch that triggers the automation. It’s connected to the Shelly 1PM Mini Gen 3.
The Solution
After some research and trial and error, I figured out how to set up the automation within the Shelly app. Here’s a step-by-step breakdown of what I did:
  1. Connect the Shelly 1PM Mini Gen 3 to Your Network: This was straightforward. I just plugged it into a power source and followed the on-screen instructions to connect it to my Wi-Fi.
  2. Add the Shelly Plugs to Your Network: Similarly, I connected each Shelly Plug to my network using the app.
  3. Configure the Automation: This was the trickiest part, but I managed to get it sorted. I set up a rule within the Shelly app that says, “When the switch is toggled on, turn on the Shelly Plugs.”
  4. Test the Setup: I tested the automation by toggling the switch, and it worked perfectly! The Shelly Plugs turned on immediately, and I could control them manually as well.
Tips for Others
If you’re looking to set up something similar, here are a few tips to keep in mind:
  • Ensure All Devices Are on the Same Network: This is crucial for the automation to work seamlessly.
  • Follow the App’s Instructions Carefully: The Shelly app is user-friendly, but it’s important to follow each step closely to avoid any issues.
  • Test Your Setup: Before relying on your automation, test it thoroughly to make sure everything works as expected.
A Little Story
It was a bit nerve-wracking at first, but seeing everything come together was so satisfying. I even surprised myself by figuring out the automation part without any major hiccups. It’s amazing how much you can accomplish with the right tools and a bit of determination!
Overall, I’m thrilled with how this setup turned out. It’s added a whole new level of convenience to my home, and I can’t wait to explore more automation possibilities in the future. If anyone has questions or needs help setting up something similar, feel free to reach out—I’m happy to help!
Cheers,
Andreas :slight_smile:
