Automating TV Volume Control with ESPHome and a Microphone
Hey everyone, I wanted to share a fun project I’ve been working on to automatically lower the TV volume when it gets too loud. I’ve always struggled with sudden loud noises from the TV, especially when watching action movies or sports. It’s a minor inconvenience, but it’s something I wanted to solve in a smart way.
The Setup
I decided to use an ESP8266 microcontroller paired with a GY-MAX4466 microphone module. The idea is to measure the sound coming from the TV and trigger a volume adjustment if it exceeds a certain threshold. Here’s how I set it up:
  1. Hardware: I soldered the microphone to a breadboard and connected it to the ESP8266. The setup was pretty straightforward, just a few wires and some careful soldering.
  2. Software: I used ESPHome to handle the sensor readings. The ADC (Analog-to-Digital Converter) pin on the ESP8266 reads the microphone’s output. When the sound level exceeds a predefined threshold, it triggers an automation in Home Assistant.
  3. Automation: The automation lowers the volume by 10% using the Yamaha receiver’s API. It’s seamless—by the time you notice the loud sound, it’s already been adjusted.
Challenges and Solutions
  • False Triggers: My kids are pretty active, and their noise was sometimes triggering the volume drop. To mitigate this, I adjusted the sensitivity and made sure the microphone is positioned to minimize ambient noise interference.
  • ESPHome Integration: Initially, I had trouble getting the sensor data into Home Assistant reliably. Using a GPIO switch as an intermediary helped stabilize the communication.
Results
This setup has been a lifesaver! It’s been running smoothly for a few months now, and I’ve had zero complaints about missed notifications or false triggers. The best part is how unobtrusive it is—my family doesn’t even notice it’s there unless I tell them.
Future Improvements
I’m thinking about expanding this project to other rooms and maybe integrating it with my smart lighting system to create ambiance based on the TV volume. If anyone has suggestions or similar projects, I’d love to hear about them!
Cheers,
I’m looking to do the exact same thing and would be interested in your process and code if you care to share.
