Hi everyone, I wanted to share my experience with automating my home’s ventilation system using Nest and Keen Vents. It’s been a journey of trial and error, but I’m thrilled with the results!
I recently upgraded my home with a Nest thermostat and Keen Vents, aiming to create a seamless smart home experience. The goal was to have the vents open automatically when the heating or cooling starts and close when it stops. Initially, everything worked smoothly, but I encountered an issue when the fan mode kicked in after heating or cooling stopped. The vents would close, and the fan would start, causing some unexpected behavior.
After some research, I discovered that using SmartApps like Rule Machine could help bridge the gap between Nest and Keen Vents. I set up a rule where the vents open when the Nest fan mode is activated and close when it deactivates. This integration ensures that the vents and fan work in harmony, maintaining optimal airflow without any manual intervention.
The process involved some tweaking, but the satisfaction of seeing everything work together seamlessly was worth it. I’m now enjoying a more comfortable and energy-efficient home environment. If anyone has similar setups or questions, I’d be happy to share more details or tips!
Cheers, [Your Name]
