Automation Ideas for the kitchen
What ideas or setups do you guys have in the kitchen?
Thank you
Just a FP1 and some smart lights plus HomePod
I have an FP300 that turn on the LED Strip 60% when you enter the kitchen (when the light level is below 20lux).
If you stay for 5minutes, the LED strip turns up to 100% (it assumes you’re doing something like cooking and you obviously need better light for that). I have also a second variant - when the light sensor of FP300 senses that the light intensity drops below 30lux, it sets the LED strip to the same brightness (we want 100% in this case, because there was already someone in the kitchen, so we skip the 5min part and assume 100% is needed).
If you go away it turns down the LED strip to 5%. It prevents sudden darkness when the sensor has a false negative (or when you’re just out of range) this automation also enables the below automation.
After one minute of no presence, the LED strip is turned off. This automation is a “trigger once” automation.
@cezary806 , thank you for your reply. Can you explain to me a little more about lux? or that is something test and try thing
In my case it was a matter of testing and checking the light level in the app. When I felt like a better light is needed - I just checked the lux level on the FP300 page in the app and then adjusted the automation accordingly.
Keep in mind that it will be sort of a compromise because of two things:
  • the Aqara app lets you set the lux level in automations with step 1 from level 1 to 10, then it’s 10 lux difference (10, 20, 30), which is not ideal.
  • the same light level may look different for our eyes throughout the year. Clouds, different sun, different season may cause the light spectrum to be different, so 20lux may be ok for your eyes in spring, but may look too dark in the autumn.
My FP300 is near the window, so those were the values that gave me the best results. Remember, in terms of the automated lights, it’s better if they kick in too early rather than too late.
@cezary806 Thank you so much!
Lux should be a standard, but I’ve found different sensors report different lux levels in the same location… so it is just a test and see :frowning:
Presence sensors turning lights on and off in different zones. You do have to delay, though, to prevent strobing.
Automated my coffee machine, which is bean to cup.
Just getting my new kitchen installed, so hoping I can do some magic with some of those new items. We’ll see.
@siobhanellis, that is what I thought
