Automation solution for alarm when you forget to close the refrigerator door or freezer door
When you have children in the house, it can happen that they forget to close the refrigerator door or freezer door. Want notification in the Aqara app and an alarm that goes off when one of the doors has been open for more than three minutes.
Can you help me design this automation, Aqarabot? @AqaraBot
@Stian 您好!非常感谢您在我们的论坛发帖,关于如何设置冰箱门或冷冻室门打开超过三分钟后发送通知及警报的自动化问题,下面是一个设计建议:
首先,您需要一个Aqara门窗传感器来检测冰箱门或冷冻室门的状态。以下是自动化设置步骤:
  1. 安装传感器:将Aqara门窗传感器安装在冰箱门或冷冻室门上,确保在门关闭时传感器正确检测到状态。
  2. 设置Aqara Home应用中的自动化
    • 打开Aqara Home应用,进入自动化设置。
    • IF条件:选择“门/窗传感器”并设置为“打开超过3分钟”。
    • THEN动作:选择“发送通知”至您的手机,并激活设备上的警报。
根据参考信息,您可以在Aqara Home应用中自主管理警报设置。请确保警报系统在应用中已激活,并显示为蓝色。
希望这能帮助到您!如果有更多问题,欢迎在此继续讨论。祝您和您的家人使用愉快!:blush:
如果需要进一步的帮助,请随时告诉我!
Thanks for your answer. @AqaraBot Can I create and play my own alarm from an Aqara Hub?
@Stian Hello Stian,
Great question! Yes, you can indeed create and play your own custom alarm from an Aqara Hub. Specifically, if you’re using the Aqara Hub M2, you have the option to upload a custom ringtone. Here’s how you can do it:
  1. Go to the Aqara Home app and navigate to your M2 Hub.
  2. Click on the “…” in the upper right corner.
  3. Select “More Settings” > “Camera Settings” > “Custom Ringtone”.
  4. From there, you can add and import your desired audio file.
  5. Complete the steps to import and set up your custom ringtone.
Once set up, you can incorporate this custom alarm into your automation rules. For instance, you could set it to trigger when a temperature or door sensor detects that the fridge door has been left open for more than three minutes.
I hope this helps in keeping those refrigerator doors in check! If you have more questions or need further assistance, feel free to ask. :blush:
Best,
AqaraBot
