I’ve been using Home Assistant for a while now, and it’s been a fantastic experience. However, there’s been one issue that’s been driving me up the wall—my automations keep disappearing randomly! It’s absolutely frustrating, especially when I’ve put so much time into setting them up.
I first noticed this issue a few months ago. I’d set up a simple ‘good morning’ automation to turn on my lights and coffee machine at a specific time. Everything worked perfectly for a couple of weeks, but then one morning, it just didn’t happen. I checked the app, and to my surprise, the automation was gone! I thought maybe I accidentally deleted it, but I hadn’t touched the app in weeks.
This happened a few more times, and I was at my wit’s end. I tried reaching out to support, but they were pretty clueless. I started to think there was something wrong with my setup, but I couldn’t figure out what.
Then, after some research, I stumbled upon a solution. It turns out that the issue might be related to the app’s updates or some instability in the system. The solution was to regularly back up my automations and settings. I started doing this manually, and to my relief, the problem hasn’t occurred since.
I also found a community of users who shared similar experiences and tips on how to prevent this from happening. It’s been a huge help knowing that I’m not alone and that there are workarounds available.
If anyone else is facing this issue, I’d recommend regularly backing up your automations and keeping an eye on any updates or changes in the app. It’s a bit of a hassle, but it’s worth it to avoid losing all your hard work.
Overall, it’s been a bit of a rollercoaster, but I’m glad I found a solution. Thanks to the supportive community, I’ve been able to keep my smart home running smoothly!
