I’ve been diving into the world of home automation with Vera, and I’ve come across an interesting challenge that I thought might be worth sharing with the community. If you’re using Vera to set up scenes, you might have noticed that pressing a scene button multiple times can sometimes lead to unintended behavior. Specifically, if you accidentally press the button twice, the scene might execute twice, which can be a bit frustrating, especially if you’re trying to create a smooth experience for your home automation setup.
Let me walk you through my experience. I set up a simple test scene where a light’s brightness is adjusted to 50%, and after 10 seconds, it returns to its previous state. This was meant to test how the scene handles interruptions or multiple presses. However, what I discovered was that if the scene button is pressed again while the scene is still running, the scene essentially restarts, causing the light to stay at 50% brightness instead of reverting to its original state. This led me to wonder if there’s a way to make scenes non-retriggerable, meaning they can’t be started again until the current execution is complete.
After some research and experimentation, I found that Vera allows you to configure scenes to prevent them from being retriggered while they’re still active. This feature is incredibly useful, especially for scenarios where you want a scene to run for a set period without interference. For instance, if you have a scene that turns on lights for 30 minutes when you enter the room, you wouldn’t want pressing the button again to reset the timer. With this setting, the scene will ignore additional presses until it finishes.
To implement this, I adjusted the scene settings in Vera to disable retriggering. Here’s how you can do it:
- Open Vera’s Web Interface: Log in to your Vera controller’s web interface.
- Navigate to Scenes: Go to the scenes section where you manage your automated actions.
- Edit the Scene: Select the scene you want to modify and click on the edit button.
- Disable Retriggering: Look for an option related to retriggering or overlapping executions. Enable the setting that prevents the scene from being triggered again while it’s still active.
- Save Changes: After making the necessary adjustments, save your changes and test the scene to ensure it behaves as expected.
This feature has been a lifesaver for me, especially when creating more complex scenes that involve multiple devices or actions. It adds a layer of reliability to my home automation setup, ensuring that scenes execute smoothly without unexpected interruptions.
If you’ve encountered similar issues with scene retriggering, I’d love to hear how you’ve handled it. Have you found other useful tips or workarounds? Let’s continue the discussion and help each other optimize our Vera setups for a more seamless smart home experience!
