Hi all! I live in Sweden and I’m thinking about adding an outdoor camera at home. Our winters mean long stretches below freezing and only a few hours of daylight, so I’m wondering how battery-powered cameras (with or without a solar panel) actually cope up here. Does capacity drop noticeably in the cold? Does a solar panel keep up in December-January, or do you end up charging manually? Any mounting tips for snow and cold are welcome too. The rest of our smart home already runs on Aqara sensors and controllers, so staying in one ecosystem would be a plus.
@axel11 Great question, and totally relatable for anyone in the Nordics! The cold and darkness combo is no joke for battery gear.
From what we know about Aqara’s battery-powered doorbell camera (G410), battery chemistry matters hugely in freezing temps. Standard alkaline batteries perform poorly below 0°C—internal resistance spikes, voltage sags under Wi-Fi/video load, and you can see apparent “drops” from 100% to 70% in minutes that are really just the firmware misreading voltage under stress[“content_id”:2"]. For a Swedish winter, lithium primary cells (like Energizer Ultimate Lithium) are the standout choice—they stay stable down to -20°C and functional to -40°C, with far less capacity loss than alkalines[“content_id”:0"]. Rechargeable Li-Po or NiMH options? Generally not recommended for harsh winters—the gel electrolyte in Li-Po gets sluggish, and NiMH voltage is too low to begin with[“content_id”:3"][“content_id”:5"].
On solar in December-January: honest answer, even the best panels struggle with ~4-5 hours of weak, low-angle sun in Sweden that time of year. You’ll likely be in a deficit and need manual charging or battery swaps. Plan for that.
Practical mounting tips:
- South-facing if possible, angled to shed snow
- Keep the lens slightly proud of the wall to avoid ice buildup
- Consider a small hood if sleet’s common
Since you’re already deep in the Aqara ecosystem, the integration win is real—just weigh whether a wired outdoor cam (if you can run cable) eliminates the winter battery headache entirely.
Anyone else running Aqara cams through a proper winter? Would love to hear real-world Swedish or Finnish experience on solar vs. swap schedules.
I run a battery camera outdoors here in Germany. In summer I’ve had no problems with it. In winter it sometimes runs out of battery when it detects a lot of movement.
Here in Québec it goes down to -35°C, so I know this problem. Batteries lose a lot of capacity in the cold, and in January they look empty even when they are not. When it gets a bit warmer, the level comes back. For solar, in December and January a few hours of low sun is not enough, and there is snow on the panel. Plan to charge it by hand in the darkest weeks.
If you can bring power or PoE to that spot, it’s really the best option for a winter like yours. If not, install the camera under the roof edge so the snow doesn’t cover the lens, and put the solar panel at a steep angle so the snow falls off.
Aqara has some interesting new outdoor camera products on the way, which could be worth considering, especially for users in colder climates.
One upcoming option features battery power and solar charging the Aqara G510, offering flexible installation without running cables. Another appears to be a wired outdoor camera with PoE, IP66 weather protection, and smart home hub functionality .
Information about the wired model has recently appeared on several websites, based on FCC certification documents.
Both could be interesting alternatives for outdoor security , but we’re still waiting for more details about operating temperatures, features, and availability.
Hi and welcome, the short sun period and coldness are definitely extreme and difficult conditions! So a battery /solar cam might get issues- definitely depends on the position you mount it!
The wired option like G5 is definitely a good option and the quality of the night view is really amazing
I agree! The combination of limited daylight and freezing temperatures makes battery-powered solar cameras challenging during Scandinavian winters. The Aqara G510 may receive only 0.9–1.4 effective solar hours per day on average from October to March (Based on information from ChatGPT), depending on location, so mounting position and sun exposure are especially important.
Manual charging may still be necessary, particularly in December and January. A wired camera like the Aqara G5 Pro is definitely a more reliable option for these conditions, with excellent night vision as an added advantage.
I’m also really curious to see how the G510 will fare during winter
