Hey everyone! I’ve been diving into optimizing my smart home setup, and I wanted to share a cool project I worked on recently. I’ve been using Home Assistant to monitor the battery life of my smart devices, and it’s been a game-changer for keeping everything running smoothly without any surprises.
The Problem
I’ve noticed that my smart devices, especially the ones that rely on battery power, tend to die at the most inconvenient times. Whether it’s my Magic Mouse or my smart lights, I wanted a way to keep track of their battery levels without constantly checking each device individually.
The Solution
After some research and tinkering, I found a way to integrate battery monitoring into my Home Assistant setup. Here’s a quick overview of what I did:
Sensor Setup: I created a sensor in my
configuration.yamlfile to track the battery level of my Magic Mouse. This involved using MQTT to send updates from my Mac to Home Assistant. -
Cron Job: I set up a cron job to run a script every 5 minutes. This script reads the battery level using
ioregand sends the data to my MQTT broker. -
Automation: I wrote a simple AppDaemon app to monitor the battery level. If it drops below 20%, it sends a notification to my phone, giving me enough time to recharge it before it dies.
The Result
This setup has been working perfectly! I no longer worry about my devices dying at the worst possible moment. Plus, it’s been a great learning experience for me in terms of scripting and automation.
Tips for Others
- Start Small: If you’re new to Home Assistant, start with a single device and work your way up. It’s easier to troubleshoot and refine your setup this way.
- Use MQTT: MQTT is a fantastic tool for sending data between devices. It’s lightweight and works great for real-time updates.
- Automation Apps: Don’t underestimate the power of AppDaemon. It’s incredibly flexible and can help you automate almost anything in your smart home.
If anyone has questions or wants to share their own battery monitoring setups, I’d love to hear about them! Let’s keep learning and improving our smart home setups together. ![]()
