I recently embarked on a project to make my battery-powered holiday lights smart, and I wanted to share my experience in case others are considering a similar upgrade. While I initially thought it might be a bit challenging, the process turned out to be much simpler than I anticipated!
First, I did some research and discovered that using smart plugs was the way to go. Instead of replacing the batteries in each light set, I could plug them into these smart plugs, which would allow me to control them via my smartphone or voice commands. I chose the Wyze Plug because of its compatibility with my existing smart home ecosystem and its reasonable price point.
The setup was straightforward. I simply plugged each light set into a Wyze Plug and paired them with my Wyze Hub. Using the Wyze app, I created routines so that the lights turn on at sunset and off at bedtime. It’s been a game-changer for me, especially during the holiday season when I want to set the mood without constantly fiddling with switches.
One thing I learned is the importance of choosing the right smart plugs. I initially tried a cheaper option, but it didn’t integrate well with my system. The Wyze Plug, however, has been reliable and energy-efficient. Plus, the app allows me to monitor energy usage, which is a nice bonus.
I also found that organizing the plugs neatly was key to avoiding any tangles or safety hazards. I used some cable clips to keep everything tidy, which made the whole setup look professional.
This project has not only added convenience to my life but has also been a fun way to get into the holiday spirit. If you’re thinking about making your battery-powered lights smart, I highly recommend giving it a try! It’s a small investment that pays off in terms of both functionality and enjoyment.
Happy holidays and happy automating! ![]()
