I’ve been testing the new sensor and so far it’s amazing. I had a little troubleshooting at first to set up on the app, but I reached out to Aqara and a couple days later I try again to pair it and it worked perfectly. I placed in my laundry room on the dryer so when the dryer turns on and detects vibrations I have an automation the triggers on vibration and turns on the fan of the laundry room which I have connected to an Aqara light switch
Thanks for sharing! We’re glad to hear the sensor is working perfectly now. It would be great if you could also share your setup with us.
Hi @jrico742680 ! Did you stick it on a freezer?
As a vibration sensor on my dryer
I’m using it on my dryer so when it vibrates turns on the fan with an automation
I’m using the sensor as a vibrate sensor and I placed it on my dryer so when it vibrates turns on the fan that I have in the laundry room. Connected to an Aqara light switch
Ah got it ! Thanks for the info and feedback!
@jrico742680
I’ve been attempting the same thing but my sensor keeps dropping connection from the hub. Do you mind sharing some of the trouble shooting tips Aqara gave you?
Just to reset and reinstall and it works
