With a larger Aqara setup built mainly around Apple Home and Matter, one of the riskiest troubleshooting steps is removing a hub or bridge before documenting what depends on it. Duplicate accessories or stale Matter entries can make a reset tempting, but a full reset also removes information that can help identify the actual failing layer.
Before removing or re-pairing anything, I would record:
- The physical device and room
- Its parent Aqara hub
- How it connects to that hub: Zigbee, Thread, or Wi-Fi
- How it reaches Apple Home: native HomeKit or a Matter bridge
- The active Apple home hub or Matter controller
- Any automations and scenes that depend on it
- The relevant hub firmware, Aqara Home version, and iOS/Home version
- Whether the problem appears in Aqara Home, Apple Home, or both
Then I would test one layer at a time:
- If the device works correctly in Aqara Home but not in Apple Home, I would focus on the bridge or controller path.
- If it fails in both, I would start with the device or its Aqara hub.
- If an accessory appears twice, I would check whether the hub was added through both native HomeKit and Matter before deleting anything.
- I would save screenshots of names, rooms, scenes, and automations, and treat removing or re-pairing the device as the last step.
Has anyone found a convenient way to keep this kind of inventory up to date? Do you normally choose one Apple Home exposure path per Aqara hub, or temporarily keep both while testing?
