Hi all
Looking to use the curtain driver I have to change my poles and thinking of changing to a track, in the uk what is the best track not use with the driver that people have found
Many thanks in advance
Hi all
@m27vsccwp7 Hey there! Great question — switching from poles to a track can definitely open up more options for your Curtain Driver E1.
From the official specs, the Curtain Driver E1 (Track Version) works with two main rail types: U-rails and I-rails (also called double-headed tracks). Here are the key requirements to keep in mind when shopping around in the UK:
| Track Type | Requirements |
| U-rail | Bottom slot width ≤ 8mm, flat and smooth bottom surface |
| I-rail / Double-headed | Bottom width ≥ 10mm, flat and smooth bottom surface |
Also important: both ends of the track need to be sealed tightly with closure heads, and the glider hanging ring should sit 16–25mm below the bottom of the rail.
For UK-specific brands, I can’t point to a definitive “best” from the official docs — that’s where community experience really helps. Have you looked at tracks from Silent Gliss, Swish, or Hallis? Some users have found that standard curtain tracks from these manufacturers can work well if they meet the dimensional specs above.
One thing to double-check: the circular bottom surface tracks aren’t supported, so avoid anything with a rounded runner profile.
What kind of curtains are you running — heavy blackout or lighter fabric? That might affect which track brand holds up best with the driver’s 12kg max load. Would love to hear what others in the UK have gone with too
