Best way to trigger WLED presets from FP2 zones?
I’m experimenting with having my Aqara FP2 trigger different WLED presets in Home Assistant depending on which zone is occupied. Curious if others have tips for making the transitions smooth and avoiding flicker
@fuad_mirzayev It’s fantastic that you’re exploring the integration of Aqara FP2 zones with WLED presets in Home Assistant! While the reference information doesn’t specifically address WLED and Home Assistant, it does provide insights about the FP2’s zone detection capabilities that might be useful for your setup.
The Aqara FP2 supports up to 30 detection zones, and you can configure automation for each zone. To ensure smooth transitions and reduce flicker, consider the following tips:
  1. Zone Detection Setup: Make sure each zone is well-defined in the FP2 settings. You can edit the name and select the type for each zone, which helps optimize monitoring parameters for better recognition.
  2. Automation Configuration: After setting up your zones, you can integrate them into Home Assistant to trigger specific WLED presets based on zone detection. Use the automation feature in Home Assistant to link zone occupancy to lighting scenes effectively.
  3. Sensitivity and Interference Management: Adjust the presence detection sensitivity to minimize false triggers, especially in environments with potential interference sources like curtains or fans. This ensures reliable detection and smoother lighting transitions.
  4. Firmware Updates: Ensure your FP2 firmware is up-to-date for the best performance and compatibility with other smart home devices.
Feel free to share your experiences or any challenges you face. The community might have additional insights or solutions to enhance your setup. Happy experimenting!
@fuad_mirzayev It’s great to hear you’re experimenting with integrating the Aqara FP2 with WLED presets in Home Assistant—zone-based automation can create really intuitive lighting experiences!
From the reference info, we know the FP2 supports up to 30 detection zones, and once zones are set up, zone automation options are generated, which could form the basis of your trigger setup . For basic light control with the FP2, automation can be set up by selecting the FP2 in the “If” condition and the target light in the “Then” action within the Aqara Home app .
However, specific tips for smooth transitions and avoiding flicker with WLED in Home Assistant aren’t covered in the current reference. This might be a great topic to crowdsource—other community members who’ve tried similar setups might have insights on adjusting transition times in WLED, optimizing Home Assistant automation delays, or ensuring stable communication between devices.
Feel free to share updates on your progress, and let’s see if the community can chime in with their own tips! :blush:
@fuad_mirzayev To set up smooth WLED preset triggers from FP2 zones, start with optimizing the FP2’s zone configuration. Ensure you properly set “exits” or “edges” in the detection area, as this improves target identification speed, which can help with quicker and more reliable automation triggers . Additionally, accurately defining detection zones (up to 30 are supported) and setting zone types to optimize monitoring parameters can enhance recognition accuracy .
For WLED-specific transitions and flicker, since the reference information doesn’t cover this directly, you might want to check Home Assistant community forums for tips on adjusting WLED’s transition settings (like fade time or brightness ramps) or ensuring the FP2’s occupancy signals are debounced to avoid rapid triggering.
Have others in the community tried similar setups? Sharing your experiences could help refine these tips further!
