Hey everyone, I wanted to share my experience with integrating a BLE keyboard into my smart home setup. It’s been quite the journey, and I hope my insights can help others avoid some of the pitfalls I encountered!
Initially, I thought connecting the keyboard would be straightforward, but I quickly realized it wasn’t as simple as plugging it in. I tried using a Bluetooth proxy, but that didn’t work out. So, I decided to connect it directly to an ESPHome device. While this worked to some extent, I ran into a strange issue where the keystrokes were being doubled. For example, pressing ‘M’ would register as two 'M’s. This made the keyboard unusable, which was really frustrating.
After some research, I found that programming the keyboard using a specific tool was necessary. I stumbled upon a GitHub project that allowed me to map the keys correctly. It took a bit of trial and error, but eventually, I got the keyboard working as intended. However, the doubling issue persisted when connected to the ESPHome device. I’m still not entirely sure why this happens, but I suspect it might be related to how the device interprets the Bluetooth signals.
One thing I learned is the importance of proper configuration. I had to add specific parameters to ensure the device recognized the keyboard correctly. For example, including the type keyword in the battery sensor configuration was crucial. Without it, the setup wouldn’t compile, which was a bit of a hurdle.
I also noticed that the initial connection process was quite unstable. It took multiple attempts to get the keyboard to connect properly, and even then, there were disconnect errors. Once connected, however, the reconnection process was seamless, which was a relief.
If anyone else is struggling with similar issues, I’d recommend checking out the resources I used. The GitHub project I mentioned earlier was a lifesaver, and the community support on forums like this has been invaluable. It’s amazing how much you can learn from others’ experiences!
I’m still tweaking things here and there, but overall, I’m happy with how the setup is coming together. It’s been a great learning experience, and I can’t wait to see how else I can integrate smart devices into my home. If anyone has tips or tricks for BLE devices, I’d love to hear them!
Cheers, [Your Name]
