I recently embarked on a project to monitor the temperature and humidity in my bathroom using a Sonoff Basic with a BME280 sensor. The goal was to integrate this setup with OpenHAB for seamless monitoring. Here’s my journey and some tips for anyone looking to do something similar!
Setup and Configuration
I started by connecting the BME280 sensor to the Sonoff Basic. The sensor worked perfectly, providing consistent readings. The JSON output looked clean, which was a great sign. I then moved on to configuring OpenHAB. I set up the things file with the necessary channels for temperature, humidity, and pressure. The items file was next, where I defined the switches and number channels to display the sensor data.
Challenges and Solutions
Initially, I faced an issue where the values weren’t showing up in my HabPanel. After some troubleshooting, I realized that the state topics and transformations were correctly set, but the visualization in the UI needed adjustment. I ended up tweaking the item configurations and ensuring the right widgets were selected in the dashboard. Once that was sorted, everything fell into place!
Tips for Success
- Double-Check Transformations: Ensure your JSONPATH transformations are accurate. Even a small typo can prevent data from displaying.
- Widget Selection: Choose the right widgets for your data types. For temperature and humidity, gauge or text labels work well.
- Test Locally First: Before integrating with OpenHAB, test the sensor and MQTT topics locally to confirm they’re working.
This project was a fantastic learning experience. It not only helped me understand the capabilities of the Sonoff Basic and BME280 but also deepened my knowledge of OpenHAB configurations. The satisfaction of seeing real-time temperature and humidity data on my dashboard was immense!
If anyone has questions or needs help with similar setups, feel free to reach out. Happy tinkering! ![]()
