Boiler Control in the UK
What do people in the UK used to control their boiler? I enjoy using Aqara to control my radiators within Apple Homekit and the integration is seamless and enjoyable.
Myself I am using EvoHome, implemented this back in 2013 and has been pretty good but now that I have it all integrated into Home Assistant, I Simple have a dummy Radiator Valve that I can use for non EvoHome valves.
To explain a bit further, if a non EvoHome valve is calling for heat, I then tell the dummy valve to call for heat which then triggers EvoHome boiler control. I suppose I could eventually change the boiler relay but then I would need to do the reverse of my setup.
Works quite well though and I’m not locked into any specific brand for boiler/radiator control.
Still using the nest but worried they will discontinue it. What are the alternatives. Need hot water control as well.
Hive for me, but looking to downsize on ecosystems.
Hive here too but looking to get rid of it. The hub part already broke and I’ve kept the thermostat ticking over by connecting it to HA via Zigbee.
Tado for me at the moment which isn’t to bad, but would love Aqara to bring out the W200 thermostat to the UK market.
I have a Bosch Easy Control thermostat linked to my Worcester Bosch combi boiler, which is connected to and controlled by my Homey Pro. I am gradually replacing all the TRV’s with Aqara W600’s which connect nicely to both my Homey Pro and Aqara Hub M3 via Matter over Thread, utilising the temperature and humidity sensors in the FP300’s I have in every room to get the most comprehensive climate control I can.
I have Tado thermostats & radiator TVR’s all work well with home assistant integration.
I did try Aqara TVR’s once within home assistant but could not control call for heat in a reliable way unfortunatly
I have 9 Aqara Smart Radiator Thermostat E1s to control individual room radiators. I then use a Dual Relay module T1 output to tell the boiler to fire (instead of the traditional wired thermostat switch). I join the two together with an automation - if any stat calls for heat switch relay on; if all stats don’t call for heat switch relay off. I also use the second relay to control the hot water (which is heated by the boiler). Add to this, I have a number of underfloor heating circuits controlled by Aqara Floor Heating Thermostat W500.
I have set up a number of scenes, such as summer, winter, guests staying, which then alter the individual thermostats to suit the scene.
If anyone wants more detail, let me know.
In the UK, people often used to control their boiler through a system of valves or thermostats, which would either be manual or automated, but with the rise of smart home technology, it’s now common to see smart thermostats like the ones you’re using with Aqara.
I monitor my hot water tank temperature, using a normal Aqara temperature and humidity sensor, but with a mod to use an external SHT30 temperature probe: https://www.reddit.com/r/smarthome/comments/o3iwhk/aqara_sensor_with_external_temperature_probe_sht30/.
The water tank has an access tube which allows insertion of the external probe, and while the reading is not necessarily accurate, as it is not inside the water (its sat inside an access tube inside the water), I’m able to allocate a % to the amount of water remaining in the tank based upon a temperature scale - eg 60°C = 100% down to 20°C = empty (eg shower running cold!)
