Hello fellow smart home enthusiasts!
I’ve been diving into the world of smart home automation lately, and I wanted to share my experience with integrating the Broadlink Mini into my setup. It’s been a fantastic journey, and I’ve learned a few tricks along the way that I’d love to share with you all.
Initially, I was focused on getting my IR codes working seamlessly with the Broadlink Mini. I’ve managed to retrieve all the necessary codes for my remotes, and they’re now functioning perfectly. However, as I started creating multiple scripts to handle various commands, I realized that manually copying and pasting the codes every time was becoming cumbersome. It wasn’t efficient, and I knew there had to be a better way to organize this.
That’s when I had the idea to create a centralized file for my IR codes, similar to the secrets.yaml file we use for other configurations. The goal was to make my setup cleaner and more maintainable. Instead of pasting the entire code each time, I wanted to reference it using a simple syntax like !ircodes powerbutton. I’m thrilled to say that this approach has worked out beautifully!
Here’s a quick glimpse of how my setup looks now:
yaml
switches:
powertelevisie:
friendly_name: “Televisie”
command_on: !ircodes powertv
command_off: !ircodes powerofftv
This change has not only made my configuration easier to read but has also streamlined the process of adding new devices or commands in the future. It’s a small tweak, but it’s made a significant difference in how I manage my smart home setup.
For those of you who might be interested in implementing something similar, here are a few tips:
- Organize Your Codes: Keep your IR codes in a dedicated file or section to avoid clutter.
- Use Descriptive Names: Name your commands in a way that’s intuitive and easy to understand.
- Test Thoroughly: Always test your new setup to ensure everything works as expected before finalizing it.
I’d love to hear how others are organizing their IR codes and scripts. Have you found any particularly effective methods or tools that you’d like to share? Let’s continue to learn and grow together in this amazing community! ![]()
