Hi everyone, I’m excited to share my recent project of creating a kid-friendly button panel for our playroom. The goal was to design a simple, durable control panel that my children could easily use to manage their playroom environment. After some research and experimentation, I’ve got a working setup that I’d like to walk through with you all.
Project Overview
I wanted a panel with 6-10 buttons that could control various aspects of the playroom, such as lights, music, and maybe even a white noise machine. Since my kids are still young, a touch solution wasn’t ideal—it needed to be something they could press without any complexity. Battery power was also a must, as I didn’t want to deal with messy wires in the playroom.
Choosing the Right Hardware
After some research, I settled on using a set of momentary push-button switches. These are simple, durable, and perfect for small hands. I opted for a battery-powered setup using AA batteries, which provides enough power without the need for constant charging.
For the controller, I decided to use an ESP32 module. It’s compact, supports Wi-Fi, and has plenty of GPIO pins to handle multiple buttons. Plus, it integrates seamlessly with OpenHAB, which is my home automation platform of choice.
Integration with OpenHAB
Setting up the ESP32 with OpenHAB was straightforward. I used the MQTT protocol to establish communication between the ESP32 and my OpenHAB server. Each button press sends a specific MQTT message, which OpenHAB then interprets to trigger the corresponding action.
Here’s a quick breakdown of how I configured it:
- ESP32 Setup: I programmed the ESP32 to detect button presses and publish MQTT messages to specific topics.
- OpenHAB Rules: I created rules in OpenHAB to listen for these MQTT messages and execute the desired actions, such as turning on lights or playing music.
- Battery Monitoring: To ensure the panel stays powered, I added a battery level sensor that sends updates to OpenHAB every hour.
Design and Installation
Designing the physical layout was a fun challenge. I wanted the buttons to be large enough for little hands but also stylish enough to fit in the playroom. I ended up using a wooden frame with recessed buttons, giving it a clean, modern look.
Installation was a breeze. I mounted the panel on the wall at a height my kids could easily reach. The battery compartment is accessible from the back, making it simple to replace batteries when needed.
Testing and Feedback
Once everything was set up, I let the kids test it out. They loved the immediate feedback from pressing the buttons and seeing the lights or music change. It’s been a great way to teach them basic cause-and-effect while keeping the playroom environment under control.
Tips and Tricks
- Button Labels: I used clear, colorful labels for each button to make it intuitive for my kids.
- Feedback Indicators: Adding small LED lights behind the buttons provided visual feedback when a button was pressed.
- Safety First: I made sure all electrical components were securely mounted and out of reach.
Future Enhancements
Looking ahead, I plan to add more functionality to the panel, such as controlling a white noise machine or even a small fan for hot days. Expanding the number of buttons to include more features is also on my list.
If anyone has questions or suggestions about this project, I’d love to hear from you! Whether it’s about hardware choices, OpenHAB integration, or design tips, feel free to drop a comment.
Happy building!
