Building a Smart Home with zero knowledge
Starting a smart home shouldn’t be difficult.
In fact , should help you use less time to perform your daily tasks while maintaining your life style.
Back when I started, wanted everything working straight away and I’d say that was my first rookie mistake.
If there are some tips I would give to anyone starting, is focusing on one brand is Key and always go for matter/ZigBee devices.
These are my strategies guidelines when building a new smart home:
:brain: Build around behaviours, not gadgets — identify what you want the house to do automatically before buying devices.
:house: Make the house independent of your phone — your phone should be for configuration and unusual situations, not everyday control.
:eye: Sensors are more important than smart devices — presence, motion, doors, temperature and light sensors give the house awareness.
:jigsaw: Use one central brain — ideally something like Home Assistant (if you like to tinker) or a Hub that can be paired with Alexa/Matter/Zigbee/Thread/etc. working around it.
:bulb: Automate lighting based on context — time, presence, brightness and activity should determine how lights behave, rather than simple schedules.
:magic_wand: Create meaningful routines/states — Home, Away, Morning, Evening, Night, Movie, etc., instead of hundreds of isolated automations.
:thermometer: Let the environment drive automation — use temperature, sunlight, sunset, occupancy and weather to control shutters, heating, AC and lighting.
:crescent_moon: Focus on invisible magic — the best automations are things you don’t notice: gentle night lighting, shutters adjusting, the house preparing itself for bedtime, etc.
:electric_plug: Prioritise local control and physical overrides — important functions should continue working if the internet or smart-home controller goes down.
:sparkles: Automate predictable tasks, leave personal decisions manual — the house should anticipate routine needs without becoming annoying or taking control away from you.
Regarding devices would start with:
Hub M3 ( matter over thread technology and future proofing)
Smart switches instead of smart bulbs.
Motion sensor/ Presence sensors.
Let me know if you have any doubts or if there’s anything you would change.
Regards to you all.
@lord_nuno Really solid starter framework—this is the kind of advice that saves people money and frustration. I especially agree with “behaviours over gadgets” and “sensors > smart devices”; once a home has awareness, the automations feel natural instead of gimmicky.
A few things I’d add / tweak (staying Aqara-friendly):
  • Don’t over-index on “one brand” if you don’t have to—standardize on protocols instead. Sticking to one ecosystem is simpler at first, but in practice a “mostly Aqara + Zigbee/Matter” approach gives you flexibility without losing reliability. Zigbee devices also benefit from a strong mesh (more on that below).
  • Plan your Zigbee mesh early. If you go Zigbee-heavy, add a few mains-powered Zigbee routers (smart plugs, in-wall switches, wired relays) to stabilize the network. Battery sensors are great, but they don’t strengthen the mesh.
  • Smart switches vs smart bulbs: 100%—with one nuance. Switches are usually the best “household-proof” choice. The exception is if you want color scenes/circadian lighting, where smart bulbs (or smart drivers) shine—then use a controller that prevents people from cutting power to them (or use wireless scene switches).
  • Presence vs motion: start with motion, then upgrade where it matters. Presence sensors are amazing in living rooms/offices, but for hallways, bathrooms, and closets, motion is often simpler and more reliable.
  • Add door/window sensors early too. They’re cheap, low-maintenance, and unlock a lot: entry notifications, “Away” arming, HVAC pause when a window is open, bathroom fan triggers, etc.
  • Define “manual override” rules up front. For example: if someone presses a switch, pause auto-off for X minutes; if “Movie” mode is on, ignore motion lighting rules. This keeps automations from feeling “bossy.”
Your suggested starting kit (Hub M3 + smart switches + motion/presence) is a very sensible foundation. If you share what home/platform you’re centering around (Aqara Home only vs Home Assistant / Alexa / Apple Home), and the size/layout (apartment vs multi-floor house), people can suggest the best order to deploy devices and where presence sensors give the biggest payoff.
