Building a Smart Root Cellar: Temperature Monitoring and Automated Ventilation
Building a smart root cellar has been an exciting project for me, and I wanted to share my experiences and tips with the community. For those who are new to this, a root cellar is an underground space used to store vegetables, fruits, and other perishables. The key to maintaining the quality of stored produce is controlling the temperature and humidity levels, which is where smart home technology comes into play!
Project Overview
My goal was to create a root cellar in my basement with automated temperature monitoring and ventilation. I wanted the system to:
  • Monitor temperature and humidity levels in real-time.
  • Record temperature fluctuations over time (ideally every 3 hours).
  • Automatically control an exhaust fan to maintain optimal conditions.
Challenges and Solutions
  1. Temperature Monitoring:
    • I started by researching temperature sensors that could handle the cold environment of a root cellar. The DS18B20 sensor proved to be a reliable choice due to its wide temperature range (-55°C to +125°C) and ease of integration with Home Assistant.
    • I set up the sensors in multiple locations to ensure accurate readings and prevent cold spots.
  2. Humidity Control:
    • Maintaining the right humidity level (ideally between 80-90%) is crucial to prevent drying out or mold growth. I used a DHT22 sensor for humidity monitoring and paired it with a dehumidifier for automatic moisture control.
  3. Automated Ventilation:
    • To regulate temperature and humidity, I installed an exhaust fan connected to a smart switch. Using Home Assistant, I set up an automation that turns the fan on when the temperature exceeds 10°C (50°F) or humidity drops below 80%.
    • The fan runs for 10 minutes and then turns off to prevent energy waste. This setup has been incredibly effective in maintaining stable conditions.
  • I used the MQTT integration to connect all my sensors and switches to Home Assistant.
  • For visualization, I created a custom dashboard with:
    • A line graph showing temperature trends over the past 24 hours.
    • A card displaying current temperature and humidity levels.
    • A toggle switch for manual fan control.
Lessons Learned
  1. Power Supply: Ensure your sensors and actuators have a reliable power supply. I opted for battery-powered sensors with low power consumption to avoid running too many wires.
  2. Insulation: Proper insulation of the root cellar walls and ceiling was crucial to minimize temperature fluctuations.
  3. Regular Maintenance: Check the sensors and automation rules periodically to ensure everything is working as expected.
This project has been a fantastic way to combine my love for gardening and technology. It’s been rewarding to see how smart home devices can enhance traditional methods. If anyone is considering a similar project, I highly recommend starting small and gradually adding features as you gain confidence.
Happy building and happy storing! :seedling::carrot:
