Building a Smart Water Meter with Zigbee
Hey everyone, I wanted to share my recent project of building a DIY inductive Zigbee water meter. I’ve always been fascinated by home automation and wanted to find a reliable way to monitor my water usage without relying on Wi-Fi, which can be spotty in my home.
The Setup
I decided to go with an inductive sensor paired with a CC2530 module running the PTVO firmware. The sensor detects the water flow, and the CC2530 module converts the signal into a Zigbee-compatible format. I used a 4N35 optocoupler to handle the voltage differences between the sensor and the module. For power, I opted for a 5V DC supply with a buck converter to step it down to 3.3V for the CC2530.
After pairing the device with my Zigbee2MQTT setup, I configured Home Assistant to recognize the water meter as a counter. I set up an automation to increment the counter every time the sensor detects flow. To track usage over time, I added utility meters for hourly, daily, weekly, and monthly data. It’s been incredibly helpful to visualize my water consumption patterns.
Challenges and Solutions
One challenge I faced was ensuring stable communication between the sensor and the CC2530 module. I had to experiment with the wiring and power supply to eliminate any interference. Another was configuring the CC2530 firmware correctly. I found the PTVO firmware to be very flexible and well-documented, which made the process smoother.
Why Zigbee?
I chose Zigbee over Wi-Fi because of its reliability and low power consumption. It’s perfect for devices like water meters that need to operate continuously without frequent battery changes. Plus, Zigbee’s mesh networking capability ensures that the signal remains strong even in areas with poor coverage.
This project has been a great learning experience and a practical addition to my smart home setup. I’m excited to see how I can expand this further, maybe by adding more sensors or integrating it with my existing automation routines. If anyone has questions or wants to share their own DIY projects, I’d love to hear about them!
Cheers,
