After spending some time exploring the capabilities of the Shelly 1PM+, I wanted to share my experience in calibrating it for accurate power monitoring. For those who might be facing discrepancies between the readings from their Shelly 1PM+ and other devices like the AVM FritzDect 210 or Voltcraft 3000, here’s a step-by-step guide that worked wonders for me.
First, I noticed that the Shelly 1PM+ consistently reported higher power consumption values compared to my other devices. This was a bit concerning, especially when trying to maintain consistent energy monitoring across my smart home setup. After some research, I discovered that the Shelly 1PM+ allows for calibration adjustments to align its readings with other devices.
Here’s how I did it:
- Access the Shelly Cloud Dashboard: Log into your Shelly account and navigate to the device settings for your 1PM+.
- Locate the Calibration Option: Under the advanced settings, you’ll find an option labeled ‘Calibration.’ This is where you can adjust the reported power values.
- Adjust the Multiplier: By default, the multiplier is set to 1.0. I found that reducing this value slightly (e.g., to 0.84) brought the readings in line with my other devices. This adjustment effectively scales down the reported power consumption without altering the actual measurements.
- Test and Monitor: After making the adjustment, I monitored the readings over a few days to ensure consistency. It was satisfying to see the Shelly 1PM+ now providing accurate and reliable data.
This calibration process not only improved the accuracy of my energy monitoring but also streamlined my smart home setup. It’s a small tweak that makes a big difference, especially if you’re using multiple devices for power monitoring.
If you’re looking to integrate this calibration into a more automated system, you might consider setting up a simple script or rule in your smart home hub. For instance, using Home Assistant or OpenHAB, you can create a rule that automatically adjusts the calibration based on periodic checks or integrate it with your existing energy monitoring dashboard.
I hope this guide helps others who might be experiencing similar discrepancies. It’s always rewarding to tweak and optimize your smart devices to work seamlessly together, and this small adjustment definitely enhanced my overall smart home experience.
