I’ve always been fascinated by the precision and efficiency of smart home automation, especially when it comes to climate control. Recently, I stumbled upon a common issue with my thermostatic radiator valves (TRVs) where the reported temperature didn’t match the actual room temperature. This discrepancy was particularly frustrating, as it led to inefficient heating and discomfort in my home.
After some research, I discovered that the problem often stems from the proximity of the TRV’s built-in sensor to the radiator, which can cause inaccurate readings. To tackle this, I decided to implement a solution using an external temperature sensor to provide a more accurate reference for the TRV.
Here’s how I approached the problem:
Understanding the Issue: The TRV’s internal sensor was picking up heat from the radiator, leading to higher temperature readings than the actual room temperature. This caused the valve to close prematurely, resulting in uneven heating.
Solution Concept: I realized that using an external temperature sensor placed away from the radiator could provide a more accurate reading. By periodically adjusting the TRV based on this external sensor, I could ensure more consistent and comfortable heating.
Blueprint Development: I created a Home Assistant blueprint that integrates the external sensor with the TRV. The blueprint actively monitors the external sensor and adjusts the TRV’s calibration settings to match the actual room temperature. This adjustment happens over several days to allow for gradual and stable calibration.
Implementation and Testing: After setting up the blueprint, I monitored the system over a week. The results were impressive—the TRV now maintains a consistent temperature, and my heating system operates more efficiently.
Sharing the Solution: I’m excited to share this solution with the community. The blueprint is designed to be compatible with various TRV models, so I’d love to hear from others who might be interested in testing it or adapting it for their specific setups.
If you’re curious about the technical details or would like to try this solution, feel free to reach out. I’d be happy to provide more information or assist with any questions you might have.
Let’s continue to innovate and improve our smart home experiences together!
