I successfully used my g2h pro for a year with HomeKit bit went offline. I hard reset it, reset my router, turned off the 5 ghz on router, and removed cam from Aqara app and HomeKit. I attempted first to add to HomeKit and after entering pairing code it stated it couldn’t add accessory as it was “not compliant.” Also tried scanning the QR code to pair, same result. I then successfully bound cam to Aqara app and then attempted to add to. HomeKit, same result. Any help?
You may need to update your homekit certificate, contact support, they will be able to help you.
I had this on the S1e and it was exactly that.
