Hi everyone!
I’ve been using Aqara products for several years and overall I’ve been very happy with the system. However, I have an issue with my Camera Hub G2H Pro that I haven’t been able to figure out.
Several times a day, the camera seems to briefly go offline and then comes back online again by itself. It doesn’t stay disconnected for very long, but it happens often enough to be noticeable.
My Wi-Fi connection is otherwise very stable and I don’t experience similar connection issues with my other smart home devices.
Has anyone else experienced this with the G2H Pro?
I’m wondering if this could be related to Wi-Fi settings, firmware, HomeKit, or something specific to the camera itself.
Any suggestions or things I should check would be appreciated. Thanks!
Yes I have this also but only on this camera. I’m running a WiFi 6 network with WPA3 security
@Heyhey88 Hi @Heyhey88,
Thanks for sharing your experience! It’s definitely frustrating when a single device acts up, especially on a robust network like yours. Since you’re running a WiFi 6 network with WPA3 security, that might be a key factor, as older smart home devices sometimes struggle with newer security protocols or band steering.
Based on common troubleshooting steps for the G2H Pro, here are a few things you might want to check:
- Wi-Fi Band: Ensure the camera is connected to a 2.4 GHz network, as it does not support 5 GHz. If your router combines 2.4 GHz and 5 GHz into a single SSID, try separating them or ensuring the camera is explicitly on the 2.4 GHz band.
- Router Settings: Check if your router has AP isolation or Wi-Fi anti-squatter settings enabled, as these can prevent the camera from connecting properly or searching on the LAN.
- Signal Strength: Make sure the camera is within good range of the router. If the signal is weak, the connection might drop intermittently.
- Firmware & App: Ensure both the Aqara Home App and the camera’s firmware are updated to the latest versions.
If the issue persists, it might be worth checking if WPA3 compatibility is causing the instability, as some devices perform better with WPA2/WPA3 mixed mode.
If you need further assistance, please contact the Aqara Home App Customer Service Team (Profile> Help & Feedback > Customer Service) or scan the QR code:
This will be more efficient. If you do not have an Aqara Home account, “Please
click here” to create a ticket.
Thanks again for contributing to the discussion
Hey there.check into your router on devices and make sure your camera stays connected only on 2.4ghz and not on automatic and also check the power supply too as if the power provide from that supply is unstable that can also make the camera to go offline
Hello. My recommendation is a 3-amp power supply. Many power supplies are labeled as 2A, but in reality, they provide only slightly more than 1 amp. Also, check the power cord by swapping it out for another one.
