A W600/T1 report describes the valve opening after a window was closed while the external T1 showed about 23.5°C, the W600 local sensor showed 19.5°C, and the setpoint was 20°C. Those readings alone do not prove which input the controller used.
It would help if Aqara Home showed the selected external sensor and its last valid update, the temperature currently used for heat demand, and any switch back to the local sensor with a reason and time. A short valve-demand history could also separate stale data from a binding reset.
Is that active control source visible anywhere today on the W600 or other Aqara thermostats? If an external reading becomes stale, what fallback behavior would be most useful to see or configure?
Hello. I always emphasize that the T1 sensor is an inertial source of information: it has a data transmission interval of 0.5°C or approximately 1 hour. Information regarding the latest reading from the T1 sensor can be found in the Aqara Home app (W600).
Thanks, that helps locate the latest T1 reading. Is there also a field that identifies the input actually used for the current heating decision, or does that view only show the configured external sensor and its last reading? That distinction is what I was hoping the app could make visible during a suspected fallback.
My recommendation is to use the W100 sensor. I replaced all the room sensors. Now I use the T1 only for dynamic measurements (temperatures on radiators, supply/return temperatures from the boiler, etc.)…
I’d like this too. I had the same problem one level up: my Google Nest thermostat sits near radiators, so it reads warm and stops the heating while the bedrooms are still cold, and nothing tells you that’s why. Our way of resolving it was to stop using the thermostats, and write automation using Home Assistant with Aqara sensors. Seeing the latest external reading helps, but knowing which sensor made the last heating decision, and when it last reported, would save a lot of guesswork on the W600 and on Aqara’s wall thermostats, including the W800 I mentioned on the CES 2027 thread. A clear note when it falls back, something like “external sensor stale, using internal”, would be my top request.
