Can i add a product with mater and apple home?
Can I add a camera to apple home and to Apple Home too?
@jakob_happel Hello there! :wave: Thanks for stopping by the Aqara Smart Home Forum. It’s great to see you diving into the world of smart home integration!
To answer your question: Yes, you can definitely add many Aqara cameras to Apple Home. In fact, most of our camera hubs are designed to work seamlessly with Apple HomeKit right out of the box.
Here is how you can get started:
  1. Open the Apple Home app on your iOS device.
  2. Tap the “+” icon in the upper right corner to enter the “Add Accessory” page.
  3. You can either scan the HomeKit Setup Code located at the bottom of your camera or manually enter it.
  4. Follow the on-screen instructions to bind the camera to HomeKit.
This process applies to several popular models, including the Camera Hub G3, Camera Hub G2H Pro, Camera Hub G2H, and Camera E1.
Troubleshooting Tips:
If you run into any issues while adding the camera, here are a few common solutions:
  • “Failed to add accessory” or “Accessory could not be added”: This might be due to cached error information in iOS. Try restarting your iOS device and resetting the camera, then try again.
  • “Accessory already added”: After restarting your iOS device and resetting the camera, you can manually enter the HomeKit setup code to add it again.
  • “Accessory not found”: Please wait for 3 minutes after resetting the camera before attempting to add it again by manually entering the setup code.
It’s always exciting to see new devices integrated into your smart home setup! If you have any other questions or want to share your experience once you’ve got it set up, feel free to post below. We’d love to hear from you! :house::sparkles:
*This information comes from community discussions and user experience summaries and may vary by environment. Please verify carefully. Source: *
Thank u for the answer
Adding the Matter angle to this, since the bot covered the HomeKit pairing side: cameras can’t join Apple Home through Matter. The Matter specification simply doesn’t define a camera device type yet, so an Aqara camera pairs directly to Apple Home via HomeKit (HomeKit setup code), exactly as described above.
Matter comes into play for the rest of your Aqara gear: sensors, bulbs and switches paired through an Aqara hub (the hub acts as a Matter bridge) or native Matter devices can appear in Apple Home via Matter. So in practice both paths coexist fine in one Home — my own camera runs on HomeKit while the rest of my devices use Matter, with no conflict.
If your question was specifically about a camera: skip the Matter hunt and pair it straight to Apple Home with the HomeKit code.
