Can plug power alone tell when a dehumidifier tank is full?
A recent utility-room automation treats less than 5 W for ten minutes while the plug is on as a possible full-tank alert. That is a useful clue, but low draw might also be a normal compressor pause, an internal humidity stop, or a delayed start. I would be cautious about labeling the tank full from plug power alone.
For anyone combining an Aqara humidity sensor with a power-monitoring plug, what evidence separates a full tank from those idle states? I would compare humidity, plug watts, any appliance indicator, and the last compressor run over normal cycles and a manually confirmed full-tank event before choosing a threshold. If tank status is unavailable, would a ‘check dehumidifier’ alert be more reliable?
I have not tested this on a particular model; I am interested in what patterns others have measured.
What about adding a float sensor or water level sensor to the tank?
A pretty reliable hack (or Swiss Army Knife of sensors) for these situations is to use a Vibration Sensor. Simple vibration (or lack thereof) of a dehumidifier compressor is going to give a pretty reliable state status. (Also works for Washers/Dryers anything that has a slight vibration associated with an operational state)
Again, power use, ‘flood sensor,’ or a variety of other ways can achieve this objective as well. I’d say it depends on whether I have a sensor in the drawer that can solve the issue without having to buy a new device.
