Can’t wait new lamp T1
@franc_muzi Hey, love the enthusiasm!
The Aqara Ceiling Light T1M is definitely a solid pick if you’re into smart lighting with both main and ambient light options, HomeKit support, and that clean ceiling-mounted look.
Since you’re hyped about it, here are a few quick things worth knowing while you wait:
- Dual light design: Main light + RGB side ring for different vibes
- Reset method: Flip the wall switch on/off 5 times (1s on, 1s off) until the main light breathes twice
- Pairing: Works with Aqara Home and Apple Home
- Pro tip: If you ever run into control delays, check your hub distance, network stability, and whether anything high-power is interfering nearby[“content_id”:0"]
If you already have plans for how you’ll automate it or want to share your setup once it arrives, feel free to drop by—we’re all ears! ![]()
