Is it possible to decouple the top buttons so they no longer switch the H2’s power relay in Matter mode?
I think decoupled mode is exclusive to Zigbee mode.
Mind you, the switch has Thread and Zigbee modes. Thread mode follows Matter standard because it doesn’t require an Aqara hub and it has to be universal. Zigbee mode can be also used as “Matter mode” if you use an Aqara hub that is Matter-enabled. So I assumed you meant “Thread mode”, not “Matter mode”
@cezary806 Thank you. You are right. I meant Thread Mode. I don’t have an Aqura hub, I’m using an iPod Mini as HomeKit hub.
Hello. I have this switch in Matter/Thread mode and I only use the bottom buttons while the top/relay ones I may use to “reboot” my bulbs should they become unresponsive. However, it can happen that someone accidentally presses the top button and cuts power to my light bulb so I have created an automation that basically says “when top button is pressed then send the command back to the switch to press it again” so it turns right back on. Perhaps a delay of a few seconds could be useful.
I know this does not solve your question directly, but just in case if it can help you while you are waiting for Aqara to publish better firmware.
I love aqara devices and all but enabling every feature possible in matter over thread would be ideal and the customer then can decide for himself if he wants to stay in that ecosystem. Things like matter binding or decoupling are really easy for a company like aqara to implement. But somehow it’s not possible yet.
That’s one issue with aqara not enabling matter features and trying to keep customers in their ecosystem.
