Cant add smart lock u200 to hub m100
Hi
I am having trouble connecting my smart lock u200 to hub m100. The hub keeps disconnecting from the network and when I try to connect it I have to unplug it and let it sit for about 30 seconds before it is detected so that it can start connecting but it still fails in the end. I think there is something wrong with my hub.
I have tried several different power sources including a power bank but the hub continues to behave strangely.
Hi there and welcome to the forum.is your hub near to you router?did you try to restart your router and make an factory reset of the hub by pressing 10 times in an row the power button?
Hi, welcome to the forum. Is the power supply for the M100 powerful enough? It’s possible the M100 is running out of power.
Hi!
I have it on a power bank and I moved it to different places. Near the lock and tried near the router but none of that worked.
When I initially made the connection I was in the wrong region and I was forced to reset it then. But I haven’t tried resetting it more times after that. But I’m trying to reset
Thanks for your answer!
Hi
I can power other heavier things on it. So I think so. I have a power bank for even higher power that I can try with.
You also need as @gafich10 mention and powerful power bank witch gives you an continuum electricity as if is an power bank to charge devices that is not so good option as the power needs to be constant as if it is not then that could lead on network disconnection and even the device going offline.same thing happens with the 5v cheap chargers to power an hub you need an good power supply.i am telling you for my experience as since I changed my power supply on my M3 hub now is running great and never had an offline device using it.my be if you have an 5v apple charger try with that and see if will work better
Update:
I was able to connect the lock but it last connection again and didn’t reconnect. My conclusion is that the hub is not made for my house and will change to one which is connection with a cable instead.
Thanks for all help in the short time I posted the problem. With your help I was able to connect even though it lost it again. So thanks!
Hi, the M100 should be powerful enough… but maybe your house and walls make it difficult to get a constant and powerful connection.
