Can't complete route calibration roller driver e1
Hi everyone,
I’m having persistent issues calibrating my **Aqara Roller Driver E1 ** and I’m hoping someone here (or Aqara staff) can help.
Problem
Whenever I try to set the open/close positions in the Aqara Home app, the setup fails with the error:
“Route setup failed, please try again!”
Because of this, I can’t complete the calibration. It returns to settings that it had before the calibration.
What I have already tried
  • Fully charged the device
  • Moved the curtain driver right next to the hub during setup
  • Removed the device from the Aqara app
  • Performed a factory reset (long press until rapid blinking)
  • Re-added the device from scratch
  • Checked and confirmed the app region (Europe)
  • Verified hub firmware is up to date
  • Checked mechanical installation (curtain moves smoothly by hand, no obstruction)
  • Tested local button control (motor responds normally)
Despite resetting, the device sometimes retains its name/settings, which makes me suspect cloud or firmware-related state is not fully cleared.
Environment
  • Aqara Home app (latest version)
  • Region: Europe/Netherlands
  • Hub: E1
  • Curtain Driver E1 (track version)
Observation
The device connects fine and reports status/battery correctly, but route calibration consistently fails, even when placed very close to the hub.
If anyone has encountered this before:
  • Is this a known firmware issue?
  • Is there a way to force a deeper reset or re-initialize the route setup?
  • Or is this likely a defective unit?
Any help or insight would be greatly appreciated.
Thanks in advance!
@dayo1 You seem to be experiencing an issue with route calibration for your Aqara Roller Shade Driver E1. You can contact customer support for assistance. Contact the Aqara Home App Customer Service Team (Profile> Help & Feedback > Customer Service) or scan the QR code:
I found a solution, there was another driver with the same issue so I suspected the hub which was indeed the culprit. Changing my phone to 2.4hz fixed it.
@dayo1 Thanks for sharing your solution! It’s great to hear you identified the hub as the potential culprit and resolved the route calibration issue by switching your phone to 2.4GHz Wi-Fi. Your experience is super helpful for other users who might encounter the same problem—don’t hesitate to share more tips or insights if you come across anything else
