Cards conditional formatting 9n dashboard
Hello, I have a board with several temperature sensors and I was wondering if it’s possible to apply some conditional formatto the cards, like background red in case the temperature is above a specified value, or blue if below another value.
Thanks
Francesco
@ffelix Hey Francesco! Great question — visual cues like color-coded cards would definitely make dashboard monitoring much more intuitive.
From what I can see in the reference info, the Home Board supports multiple card styles for different device types (like small, medium, vertical, and large cards for lighting with brightness/RGB controls), and you can switch between these during editing. However, I don’t see any mention of conditional formatting based on sensor values — like dynamic background colors that change automatically when temperature crosses thresholds.
Your automation options with temperature sensors are solid though: you can set triggers for when temperature rises above, drops below, or reaches specific values to kick off automations[“content_id”:0"][“content_id”:1"][“content_id”:2"]. But that’s for automation flows, not visual card formatting on the dashboard itself.
So unfortunately, dynamic conditional formatting for dashboard cards doesn’t appear to be a supported feature right now. That said, it’s a really practical idea for quick visual scanning — worth suggesting! If you’d like to put in a feature request, you can reach out through the Aqara Home App Customer Service Team (Profile > Help & Feedback > Customer Service) or scan the QR code:
This will be more efficient. If you do not have an Aqara Home account, please click here to create a ticket.
Anyone else in the community found a workaround for this, or maybe using third-party dashboard tools?
I think you cannot (currently). But I think Aqara Life will have this feature. This is a new Aqara app (currently in beta, available through TestFlight, you can find more info by searching the forum) and this new app will allow to write custom plugins.
You could write a plugin that shows the temperature from the sensors as widgets and changes the background based on the temperature/climate in each room.
