I recently encountered a frustrating issue with my CCU3 where it would crash whenever my Fritzbox was rebooted. The red light would stay on, and nothing would work until I manually restarted the CCU. This problem started after updating to firmware version 3.55.10. At first, I was concerned that the firmware update had caused some instability, but after some research and troubleshooting, I found a solution.
Initially, the issue was quite perplexing. I noticed that the CCU3 would freeze and require a hard reset after each Fritzbox reboot. This was inconvenient, especially since I rely on my smart home setup for daily routines. I decided to reach out to the community for advice and found that others had experienced similar issues after firmware updates.
After some experimentation, I discovered that the problem was related to the interaction between the CCU3 and the Fritzbox during the reboot process. By adjusting the startup sequence and ensuring that the CCU3 had sufficient time to initialize before the Fritzbox completed its reboot, the issue was resolved. I also performed a full firmware reinstallation to ensure there were no residual issues from the previous update.
It’s a relief to have this problem sorted out. The CCU3 is now running smoothly again, and I can confidently say that the firmware update, once causing headaches, has been successfully integrated into my system. This experience taught me the importance of thorough testing after firmware updates and the value of community support in troubleshooting.
If anyone else is experiencing similar issues, I recommend checking the firmware version compatibility, adjusting startup sequences, and reaching out to forums for additional insights. Happy smart home tinkering! ![]()
