Challenges and Solutions with Sync Module 2 and Tado X Thermostat
Hello everyone, I wanted to share my recent experiences with the Sync Module 2 and the Tado X radiator thermostat. It’s been a bit of a rollercoaster, but I’ve learned a lot along the way!
Sync Module 2 Connection Issues
I’ve been struggling with the Sync Module 2 not reconnecting after being removed from my account. Despite multiple attempts to connect it to different networks, the app stalls at contacting Blink servers, and the module turns into a solid red light. I’ve reached out to technical support, and they’ve been helpful, but they keep pointing towards a network issue. However, running the RouteThisHelps app three times confirmed that my network is fine. I’m curious if others have experienced similar issues or if there’s a workaround or a definitive solution. Is this a hardware problem, or could it be related to the time of day? Any insights would be greatly appreciated!
Tado X Thermostat Mystery
On another note, I’ve encountered a peculiar issue with my Tado X radiator thermostat. It randomly thinks it’s unmounted, causing the heat to skyrocket. This has happened twice now in different rooms, and it’s quite alarming. The app doesn’t even send an alarm, which is concerning. I’ve had similar thermostats before, and they never had this problem. I’m wondering if this is a common issue or if there’s a way to prevent it from happening. Has anyone else experienced this, and if so, how did you resolve it?
Seeking Solutions
Both issues have been quite frustrating, but I’m determined to find a resolution. For the Sync Module 2, I’m considering reaching out to Blink support again or looking into any firmware updates that might address the issue. As for the Tado X thermostat, I’m planning to contact their customer service to see if they can shed some light on this unexpected behavior.
I’d love to hear from anyone who has faced similar challenges or found effective solutions. Let’s collaborate and troubleshoot these issues together!
Cheers,
