Challenges with Device Synchronization Across Multiple Apps
I’ve been really enjoying integrating various smart home devices into my daily life. However, I’ve encountered a bit of a hurdle when it comes to maintaining device synchronization across different apps. Let me share my experience and see if anyone has encountered a similar issue or has some advice to offer.
I primarily use OpenHAB to manage my smart home setup, and I absolutely love how customizable and flexible it is. One of the devices I’ve integrated is a Siemens PLC for controlling some lighting in my chicken coop. The setup works smoothly when I use the OpenHAB app or web interface. However, when I switch over to another app to control the same light, I lose synchronization. For instance, if I turn the light off in the OpenHAB app and then turn it on in the other app, the states don’t align properly, which is a bit frustrating.
Let me walk through what happens in more detail. When I turn off the light in OpenHAB:
  • The item GF_chickencoop_LightONOFF receives the OFF command.
  • The state changes from ON to OFF.
  • The status item GF_chickencoop_LightStatusONOFF updates from OPEN to CLOSED.
This works perfectly within OpenHAB, but when I use another app, the status doesn’t update automatically. I’d love to find a way to ensure that the status of the switch is always reflected accurately, regardless of which app I use to control it. Maybe there’s a rule or a configuration tweak that can help achieve this synchronization.
I’ve considered using a rule to check the current status of the light before sending a command. For example, if the light is already OFF, the rule could prevent sending another OFF command. This might help maintain consistency across different apps. However, I’m not entirely sure how to implement this effectively in OpenHAB. Any insights or suggestions would be greatly appreciated!
It’s a shame because the potential for seamless integration across multiple apps is huge, and resolving this issue would make my smart home setup even more robust. I’m hopeful that the community can shed some light on this matter. Thanks in advance for your help and suggestions!
