Changing WiFi password
I want to either change my Wifi name or just the password. It seems that if I do I have to go to every Aqara device to remove and add again. That’s a pain for I have about 12 devices. Is there an easy way?
Only wifi devices need to be paired again (like your hub). Zigbee devices don’t have to be paired again, they are paired with your hub.
If you “reset” your hub (aka hold the button until it enters pairing mode again) you will be able to add it in the app again and the hub will NOT lose any settings. It will just connect again to the new wifi.
Generally Aqara devices have this feature that, once they are paired with your account, they won’t forget their configuration unless they are paired to another. So you can just pair them again and they will simply go back to their previous configuration.
Thanks. It is as I guessed. I have been putting it off in view of the number of devices to reset.
