Hi, welcome to the forum!
That’s a fair suggestion, having separate subscriptions. But there are actually already quite a few options available – the main thing is knowing about them.
Nobody is forcing you to use the Aqara subscription.
If you want AI features, you can simply add the cameras to Apple Home and use Secure Video, including Apple’s own local object detection, for 99 cents a month with iCloud+.
You can also use an SD card (for example with the G100) go for a camera with enough internal storage, or, as you suggested, build your own setup with Home Assistant. The G5 Pro, for example, is available in two versions with different amounts of internal storage, so you can pick whichever fits your needs.
Aqara also showed the upcoming HomeStation M410 again at IFA. It’s not released yet and currently works with the new Camera G510 (Battery), Aqara’s outdoor camera with an integrated solar panel. It’s still early days, but the idea is interesting: a central hub for camera and smart-home security with local storage.
So there are quite a few alternatives. You just need to decide which way you want to go before buying the camera. Personally, I use a NAS and then push the recordings to a cloud provider of my choice.
I also don’t think Aqara is deliberately putting basic features behind a paywall just to annoy people. A lot of it simply comes down to hardware.
If you buy a more expensive camera, such as the G5 Pro or the G410 Video Doorbell, you get enough processing power to handle things like facial recognition and other advanced AI features locally, without needing a subscription.
With cheaper models, such as the G400, the hardware simply doesn’t have the same processing power. More complex AI processing therefore has to be done in the cloud, and Aqara passes some of those server costs on through the subscription. That’s not really unusual – it’s often the trade-off for a lower upfront price.
That’s why I think it’s worth checking the specs and, in particular, the available storage and AI capabilities before buying. That way, you know what you’re getting into and won’t be surprised by cloud costs later.
And let’s be honest: manufacturers trying to generate recurring revenue through SaaS subscriptions isn’t exactly a new thing these days. Even Home Assistant has a subscription now to help fund its development (and I’m sure the Open Home Foundation’s IFA booth wasn’t exactly cheap either
In the end, there are different ways to set things up. It’s mostly a matter of deciding how much you want to spend upfront, what you want to keep local, and whether you’re okay with using a cloud service.
