I recently decided to upgrade my home’s lighting system by replacing traditional switches with Z-Wave smart switches. My setup is a bit particular—I have a three-way configuration with one dimmer and one switch. The challenge was figuring out which Z-Wave add-on switch to choose to maintain functionality while adding smart features.
I stumbled upon two options: the GE 12723 Add-On Switch and the GE 45610WB Z-Wave Add-On Auxiliary Switch. The GE 12723 seemed like an obvious choice because it’s much cheaper, but I wasn’t sure if it would fully integrate with my existing setup. I wanted a switch that could work seamlessly with my Z-Wave ecosystem and provide reliable performance.
After some research, I realized that the GE 45610WB might be the better option despite its higher price. It offers more robust features and better compatibility with Z-Wave, which is crucial for my three-way setup. I decided to go with the GE 45610WB and installed it alongside the GE 12724 dimmer. The installation process was straightforward, and the integration with my smart home system worked flawlessly.
Now, I can control both switches through my smartphone and automate my lighting based on my schedule. The added convenience and energy efficiency have made the investment well worth it. If you’re considering a similar upgrade, I’d recommend thoroughly researching each option to ensure it meets your specific needs and integrates well with your existing setup.
