Configuring Airam LED Strips with Home Assistant: A Step-by-Step Guide
Hey everyone, I wanted to share my experience with configuring Airam LED strips in Home Assistant. I recently purchased some Airam RGBW LED strips and was excited to integrate them into my smart home setup. However, I quickly realized that they aren’t natively compatible with Home Assistant. After some research, I found that using the Tuya app and the LocalTuya integration was the solution for me. Here’s how I did it:
First, I set up the LED strips using the Tuya app. This allowed me to control them locally, which was a great start. Then, I integrated them into Home Assistant using the LocalTuya component. This process was straightforward, and I was able to control my LED strips seamlessly through the Home Assistant interface.
For anyone else looking to do the same, here’s a quick overview of the configuration I used:
“platform”: “localtuya”,
“devices”: [
“id”: “your_device_id”,
“name”: “Airam LED Strip”,
“host”: “192.168.1.100”,
“local_key”: “your_local_key”,
“protocol_version”: “3.3”,
“optimistic”: false,
“state_object”: “state”,
“state_on”: “on”,
“state_off”: “off”
I hope this guide helps someone else who might be struggling with integrating their Airam LED strips into Home Assistant. It’s always great to share knowledge and help each other out in the community! :rocket:
