Configuring Blinker Functionality with HM-IP 8Fach Aktor
Hey everyone, I’m really excited to share my recent project with you! I’ve been working on integrating my e-bike’s lights into my smart home setup using an HM-IP 8Fach Aktor. While it’s been a bit of a learning curve, I’ve managed to create a functional solution that I’m pretty proud of. Here’s how it all came together:
The Goal
My main objective was to control my e-bike’s headlights and taillights using my existing smart home infrastructure. I wanted to be able to turn them on and off from my phone or even set up some automation rules. Plus, I thought it would be cool to have a working blinker system for safer riding.
The Setup
I decided to use the HM-IP 8Fach Aktor because it’s a versatile device that I already had on hand. I set it up to control both the headlights and taillights using a 4-channel sender. While it’s not the most efficient setup, it does the job for now. I’ve programmed short and long presses on the sender to control different functions—short presses for quick on/off and long presses for more complex actions like activating the blinkers.
The Challenge
One thing I struggled with was ensuring that the blinkers only activate on one side at a time. In my car, I can only blink left or right, and I wanted the same functionality for my bike. After some research, I found that I could use virtual channels to simulate this behavior. It took a bit of trial and error, but I finally got it working!
The Solution
Here’s a quick breakdown of what I did:
  • I set up two virtual channels for the blinkers, one for the left and one for the right.
  • I programmed the HM-IP 8Fach Aktor to toggle these channels independently.
  • I added a delay to ensure that only one blinker can be active at a time.
The Outcome
I’m thrilled with how it turned out! My e-bike now has fully functional blinkers that integrate seamlessly with my smart home setup. It’s not just a cool project—it’s also made my commutes safer. Plus, being able to control everything from my phone is a huge convenience.
Tips for Others
If you’re thinking about something similar, here are a few tips:
  • Start simple and gradually add complexity.
  • Don’t be afraid to experiment with virtual channels and delays.
  • Take advantage of the community resources here—they’ve been invaluable to me!
I’d love to hear if anyone else has tried something like this or has suggestions for improvement. Let’s keep the ideas flowing!
Cheers,
